What Can Stock 95Z28 Fuel Pump Handle?
I believe I will need a new pump. I didnt check pressure under WOT but it misses and goes lean at high throttle so im guessing my pump can not keep up. Its a 383. Loyd intake and heads LE2. 450hp ish maybe a bit more?.
I will check for sure tomorrow. BUT if I do need to upgrade, can I use a inline booster? or should I go with a in tank pump. recommendations. thanks
