Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Boost gauge wiring problems
Old Mar 26, 2009 | 06:45 PM
cam2000z28's Avatar
Post Boost gauge wiring problems
Need help with a camero 2000 hot wire for my boost gauge. Is the fuse panel inside the car have a fuse link that stay hot when you turn the key on?
Old Mar 26, 2009 | 06:47 PM
cam2000z28's Avatar
wiring issue
boost gauge wiring issues. need a live fuse in a 2000 camero fuse panel inside car
Old Mar 26, 2009 | 08:46 PM
No need to post on multiple forums. You already posted this, and you got answers. I told you how to wire up the gauge. Your first post was moved to "General 67-02 F-Body Tech". A "boost gauge" has nothing to do with fuel or ignition, so it shouldn't have been posted here.
Here is a link to your first post, with an answer, including a photo.
https://www.camaroz28.com/forums/sho...d.php?t=676839
Read the forum descriptions, and post a question only once on the correct forum.
PS: You might not be getting answers, because of your misspelling.... its a Camaro, not a Camero.
DirtyDaveW
Dec 1, 2016 05:37 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
Burn_Out
Aug 18, 2002 08:49 AM
x7x7
Aug 15, 2002 06:49 PM
