Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
help picking injectors?
Old Feb 19, 2009 | 09:23 PM
1996camaroSSclone's Avatar
The engine is a forged 383 force fed by a PT88. What is the best injectors for this application?
Old Feb 19, 2009 | 09:42 PM
MikeGyver's Avatar
What's your realistic engine HP target?
and are you changing the fuel pressure? or sticking with the stock 43.5psi.
Old Feb 19, 2009 | 09:51 PM
HP is going as high as I can get it without killing myself and yea the pressure is going to be going up quite a bit.
Old Feb 20, 2009 | 01:54 AM
MikeGyver's Avatar
lol given that vague of an answer the size you want is, "as big as possible/lbs per minute"...
Old Feb 20, 2009 | 01:56 PM
I was thinking around mid 900s TOPS. That will probably be the absolute max I will ever see(I'd rather over estimate my power output than underestimate it). I was thinking around 96# injectors?
Old Feb 21, 2009 | 12:05 AM
"mid 900's" at the flywheel or at the rear wheels? If at the rear wheels, what is the drivetrain?
If the fuel pressure is "going up quite a bit"..... you need to pick a value, so the injector flow rate can be converted to the pressure the injector was rated at to the new pressure. Pressure will also determine the type of injector you need.
Old Feb 21, 2009 | 12:13 AM
MikeGyver's Avatar
Based on a typical brake specific fuel comsumption of .625 for turbocharged engines, and running under an 80% duty cycle, you'll need roughly 88lbs/min @3bar fuel pressure, and 76lbs/min @4bar to achieve 900hp.
You'll need low impedance injectors and something to drive them... but yeah 96 sounds good to allow plenty of overhead.
Old Feb 21, 2009 | 01:07 PM
I'm new to the whole fuel part of things so I need alot of help. The car is a 94 firebird with a 383 stroker, 8.5 to 1 CR, PT88, 1.80 gear glide, 4.56 gears, cam is still undecided, new ecm is also undecided but was thinking about the F.A.S.T. XFI. Any input is helpful at this point cuz this is where I'm lost
Old Feb 21, 2009 | 11:39 PM
rskrause's Avatar
Moderator
I use an Electromotive system for engine management on my race car and I like it a lot. It's what I recommend.
Rich
Old Feb 21, 2009 | 11:57 PM
Rich
I'm liking all the features it provides. Could you help me out and give me a list of the parts and part numbers I would need to use this system on my LT1? Also where would be a place I could get this programmed at?
Old Feb 22, 2009 | 08:26 AM
rskrause's Avatar
Moderator
It would be best to call them or a dealer. As far as tuning, if you can tune one EFI system, you can tune another (well, that's oversimplifying, but just a bit). But anyone who does EFI tuning can do it.
Rich
Old Feb 22, 2009 | 12:16 PM
Thanks for the help Rich.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
4586
Apr 29, 2015 01:43 PM
3TAS4ME
Apr 15, 2015 02:24 PM
drptop70ss
Mar 26, 2015 01:50 AM
siguy
Nov 27, 2014 10:07 AM
