Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel injector question
Old Apr 1, 2009 | 03:27 PM
josh77888's Avatar
Exclamation fuel injector question
i have a 93z i believe it has stock 24lb. What would you guys estimate on hp gains if i swapped over to 32 or 36lb injectors.
stock heads and i have a slightly bigger cam then stock.
Old Apr 1, 2009 | 05:33 PM
Kevin Blown 95 TA's Avatar
You won't get a horsepower gain unless you are starving it for fuel right now and it is running too lean for lack of enough injector. With that in mind, larger injectors don't directly give you a horsepower gain.
Old Apr 1, 2009 | 10:52 PM
93 was the only year with 22 #/HR injectors. With your limited mods, they should still be OK.
Old Apr 1, 2009 | 11:01 PM
MikeGyver's Avatar
Increasing injector size is done to allow greater fuel flow on engines that are flowing signicifantly more air and therefore require more fuel. (i.e. turbo, not cold air intake)
The computer will need to be retuned to rescale fueling.
Old Apr 2, 2009 | 08:46 AM
josh77888's Avatar
but when i get heads, throttle body, bigger cam, and intake. thats when i should go up in fuel injectors? what size would be a good one.
and mine has 24lb already researched it.
Old Apr 2, 2009 | 05:43 PM
30# maybe or slightly larger.
Old Apr 3, 2009 | 05:28 AM
Depends on the flywheel HP, quality of the tune, efficiency of the combustion chamber configuration, etc. As a minimum size, get an injector that is 0.07 X the flywheel HP. A 450 HP setup would require 0.07 X 450 = 31.5 #/HR minimum. In that case, I'd go with a 36.
Nothing wrong with going to a larger injector, within reason. It helps keep the duty cycle down. But you will not see any extra HP from the injectors' excess capacity.
Old Apr 3, 2009 | 06:56 PM
mrmint69's Avatar
85 to 93 came with 22lb. Here an Ebay auction with the info. http://cgi.ebay.com/ebaymotors/FUEL-...Q5fAccessories
AdsoYo
May 2, 2018 03:21 AM
LT14LIFE
Feb 9, 2015 09:35 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
