Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Need help with fuel problem
Old Feb 13, 2009 | 12:24 PM
Domss2000's Avatar
last night the car had over heated then cooled down it was the electric water pump. Then after having it on for a bit it turned off and i have no fuel psi at all on the gauge the pump is new i can hear it still working. i opened it to check and it was good. what do you think it can be fuel filter, regulator is a holley. or the fuel thing.
Old Feb 14, 2009 | 02:26 PM
Post the specifics of the car.... year, model, engine, tranny and any major mods. Without that info, you reduce your chances of getting an accurate answer (or any answers at all). Us the "Signature " field and you will not have to type that info every time you post. We can guess you have some sort of 2000, but there are many people here have have embedded car info in their screen name that has nothing to do with their car.
When you say you have no fuel pressure on the gauge, what gauge are you looking at - a test gauge connected to the Schrader valve on the rail, or an electronic aftermarket in-car gauge?
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
