LT1 Injectors
LT1 Injectors
I have a mostly stock 95' LT1, and I have the Intake off to put new lifters in. My question is while the intake is off is there anything that can be done to the injectors.......like cleaning them or something? Thanks Mike
If they are working properly...dont touch them. Just put the intake back on. If you just want to clean the outside of any grime etc...that should be fine but Id leave them alone if they're working properly.
Why are you replacing the lifters?
well while im at it I wanna get the Intake powder coated........and I believe the lifters are collapsing cause this is the second time that a rocker has jumped off. Both times it happened the engine was cold and its been a different rocker each time. Also when I fire it up it has a loud tap for a few seconds........Hopefully new lifters will solve the problem and I'm adding 1.6 roller rockers and LT4 springs
Jul 4, 2005 05:00 PM
