Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Help Chose My Fuel Pump - 383 LE2
Old Jun 13, 2009 | 11:47 AM
ENRKyle20's Avatar
I was thinking about getting a booster or some other cheap way but I have so much money into this car I don't want to skimp on the fuel pump.
I am going to cut a trap door so I don't have to remove the tank. Then I will put a good pump in there. I believe I will also need some better wiring?.. Is that correct?
Does anyone have any feedback on this racetronics kit?
http://www.racetronix.com/RX-FLT1-FPKG-2.html
This seems to be a very complete kit. ordering the $208 one with the pump and wires will take care of my for good correct?.. (even with a little nitrous - wet)
Old Jun 13, 2009 | 11:52 AM
ENRKyle20's Avatar
I did some searching on ebay and it looks like I can get that identical pump for cheaper?..
Old Jun 16, 2009 | 07:07 PM
z28_theantirice's Avatar
Go with the RaceTronix kit, easy plug and play install. I to installed them this setup in my car last summer and haven't looked back.
Old Jun 18, 2009 | 08:06 PM
94zgreenmachine's Avatar
I have the same racetronix kit with the wiring. The wiring portion of the kit supplies full voltage to the pump under wide open throttle.
kaoticcamaross
Feb 17, 2015 03:13 PM
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
