Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel cooling
Old 04-30-2009, 08:51 AM
cause4panic's Avatar
Fuel cooling
Has anyone used this style of cooler? Im having some fuel heating troubles running a large fuel pump on the street. I was thinking to run this thing in the return line mounted under the car somewhere.
cause4panic is offline
Old 05-01-2009, 09:55 PM
Moderator
rskrause's Avatar
You might want to consider a fuel pump controller. That's what I did.
Rich
rskrause is offline
Old 05-15-2009, 10:17 AM
mzgp5x's Avatar
I run (2) Walbro intank 255lph pumps with KB BAP. I also have a finned fuel heat exchanger under the car. I purchased from Summit. B.
mzgp5x is offline
10-31-2016 11:09 AM
grabbem88
04-16-2015 06:57 PM
MattFick
02-15-2015 10:16 PM
The Seer
Classic Engine Tech
11-26-2014 05:55 PM
IDOXLR8
08-06-2002 12:30 PM
Quick Reply: Fuel cooling
