Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Too big injectors?
Old Oct 1, 2009 | 04:53 AM
95Yardbird's Avatar
Too big injectors?
It says I need 37# injectors. Would it be too much to run 42# injectors? Can you run LSx injectors on a LTx?
Old Oct 1, 2009 | 10:02 AM
fast83z28's Avatar
42# injectors will work fine in place of 37#ers ......you could run 60#ers for that matter...you just cant run too small of an injector.....the computer needs to be tuned for which ever injector you use. I am not posative if any of the LSx injectors will work with an LTx manifold. I do know that LS1 and LS6 had taller injectors than LS2 and LS7.
Old Oct 1, 2009 | 08:19 PM
95Yardbird's Avatar
Cool, Do I need to factor in a nos shot to pick injector size?
Old Oct 2, 2009 | 10:19 AM
rskrause's Avatar
Moderator
Not if it's a wet system. If it's a dry sytem, yes.
Rich
Old Oct 2, 2009 | 09:39 PM
LS1 and LT1 injectors are physically interchangeable. However, they are flow rated at different operating pressures. A 28#/HR LS1 injector, flow rated at 58psi, will flow the same as an LT1 24 #/HR injector, when operated at the 43.5psi on a stock LT1.
Old Oct 2, 2009 | 11:53 PM
95Yardbird's Avatar
All good info thanks
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
gomaro
Events and Cruise Spots
May 6, 2015 09:02 AM
titanthomas
Apr 18, 2015 11:44 PM
