Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
32 lb
Old Jun 23, 2009 | 10:34 PM
pattracing212's Avatar
32 lb
almost done with my 357 le2 build, i have installed the 32lb injectors already. can i start it and do the break in with these injectors? then can i drive it 30 minutes to the shop to get it tuned? i can trailer it there if i have to but woudl like to put soem heat cycles through the trans and rear end.
Old Jun 23, 2009 | 10:44 PM
What size injectors in the current tune? If its set up for the stock injectors, the 32's will overfuel it by more than 28%. The long term fuel corrections can only pull out about 15% fuel, and then it relies on the short-terms, which are going to be hit-or-miss in being able to control the fuel. Pouring in all that extra fuel could wash the lubrication off the cylinder walls, and damage the rings.
If you have a stock tune, put the stock injectors back in. Then don't take it anywhere near red line.
