Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
no crank
Old Jul 18, 2009 | 06:11 PM
marines_sf's Avatar
no crank
i have a 97 z28 automatic all stock lt1. the other day i went to start my car for work and when i put the key in all my lights came on except for my odometer didnt light up. the security light comes on for about 5 seconds then shuts off which i think is normal and when i go to start the car nothing happens what so ever. the battery is good and i even go under it to cross over the starter and it will spin but never engage. i can here my fuel pump prime and everything. i have checked all my fuses and cables are tight. not sure if it could by my bcm, security of even my starter?
Old Nov 4, 2009 | 08:03 PM
wildehaven's Avatar
No Crank
sounds like the problem I'm having please help
Old May 26, 2011 | 11:29 PM
Bobqiont's Avatar
Re: no crank
Same problem I am having to a friend of mines camaro did the same thing and he had to replace the PCM I have a spare PCM I'm gonna swap out tomorrow I'll let u know how it goes
Old May 28, 2011 | 10:38 AM
Re: no crank
There's no interface with the PCM for the starter circuits, only the BCM and theft deterent relay.
From Shoebox:
http://shbox.com/1/starter_charging_96.jpg
Old Jun 2, 2011 | 03:09 PM
Uber Geek's Avatar
Re: no crank
I have the same issue. I have a 02 Z28. It is totally random but I can turn the key and sometimes it starts with no issue and other times it might take 2 or 50 turns of the key to get the car to start. Everything turns on correctly and the security light does not flash so it is not a bad key..which has been replaced. I can hear the fuse on the hood spark and the fuel pump hiss and turn on but no ignition. I have swapped out the ignition fuse under the hood. Acutally there is times that the car will not cranck no matter what I do, but do to a fit of rage one day I knoecked the plastic cover off of the small square ignition fuse and if I stick a metal opject in there the car will turn over one and start everytime. I have swapped that fuse about 5 times. I can usally get the car to start but turn the key to the start position rapidally for a few seconds and it will eventually start. It is annoying as crap.. I love it when it is raining or 100 flippn degrees outside. Any thoughts?????
Jeff1904
Jun 5, 2016 05:00 PM
68camaroboltz
Oct 5, 2015 11:56 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
