Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel line for 800hp?
Old Jan 24, 2009 | 01:49 PM
94sc383's Avatar
will the stock fuel line and fuel rails support 800 hp or is -6an lines required?
Old Jan 24, 2009 | 02:54 PM
The stock fuel supply line in a 94 (assuming that's what you have, from your screen name -why not add a "signature"?) is 3/8", which is the same diamter as a -6AN line. The stock return line is 5/16".
Are you asking about 800HP at the flywheel, or at the rear wheels? How are you making that HP level - different power adders have different brake specific fuel consumptions, which will affect the amount of fuel required to reach 800HP. Again, we can assume its blown, because of the "sc" in the screen name, but why not eliminate the uncertainty?
I run 800HP at the flywheel (500HP NA + 300-shot of N2O) with a -6AN supply line and a -6AN return line. But my rails have been modified to run in parallel, rather than in series. That reduces the pressure differences between the individual injectors.
Old Jan 24, 2009 | 03:57 PM
94sc383's Avatar
its actually a 357 with twin turbos. i never changed my sn. 94' is correct. 800hp at the crank.
Old Jan 27, 2009 | 01:21 PM
94sc383's Avatar
forgot to add fuel pressure will be around 60psi.
Old Jan 27, 2009 | 03:16 PM
rskrause's Avatar
Moderator
Probably be ok.
Rich
HectorM52
Jul 30, 2017 11:46 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
