in-line fuel booster ?
Remove inline fuel booster?
I am replacing my in tank fuel pump with a wa. Hp Fuel pump, I put a inline fuel pump so i woild not have to replace the one in the tank.. Dumb move i made 2 years ago when i built the motor, because now it is showing signs of the in tank pump dieing.
My question is do i leave inline fuel booster in it is zex inline booster http://store.newlevelmotorsports.com/zexinfuelpum.html Or do i take it out and put a line in the place with comp. fittings? Can i kill the power to the pump and will the fuel still flow threw there, or do you have to have the pump running to boost the fuel?
Remove the inline booster pump. It will restrict flow if its not powered. And if you are getting the high pressure Walbro, you all covered on high flow/high pressure applications.
Okay I will do that, guess ill sell the thing Do you think my best bet is to install a new steel line with a comp. fitting? I have the booster right after the fuel filter so ill just have to replace that some section of line. Thanks for help
