Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Help !!!!!!!!!!!!!!
Old Jan 22, 2009 | 09:38 PM
lt1le2's Avatar
Help !!!!!!!!!!!!!!
I replaced my opti and the car started fine... before it was throwing code16 so I got another opti installed and the car fired right up but when I drove to the gas station and turned it off and tried starting it back up it does not fire up right away I have to let it sit for about 5-10 min and then it fires right up when its started its fine but when i turn it off right away and turn it back on it takes along time I hear it backfire really bad when im trying to start it. PLEASE HELP GUYS what should i do first
Old Jan 23, 2009 | 12:18 AM
What brand replacement Opti did you buy? Was it a complete unit? Have you checked to see if its setting codes again?
Old Jan 23, 2009 | 11:07 AM
lt1le2's Avatar
Opti
http://www.dynaspark.net/products.
Old Jan 23, 2009 | 11:10 AM
Black 97 SS's Avatar
backfiring, sounds like timing is off. Maybe the dowl pin on the cam is not in the correct postion on the opti?
Old Jan 23, 2009 | 12:15 PM
lt1le2's Avatar
opti
But when the car starts its perfect
Old Jan 24, 2009 | 01:02 AM
mrmint69's Avatar
I would recheck all your work and be sure everything was reinstalled corectly and is on tight. If something wasn't replaced just right it could be causing your issues. Did you do anything else while you where in there?
Old Jan 24, 2009 | 12:26 PM
Did you check for codes again?
Generally, if you put the dowel in the wrong hole in the back of the Opti, its so far off (120 cam degrees = 240 crank degrees) that it will probably not start. Its not like the splined shaft on the unvented models, where you can be off by 20 cam degrees.
Old Jan 24, 2009 | 11:15 PM
lt1le2's Avatar
z28
yes I have no codes its really weird I can drive and drive for ever with no problems its just when I turn it back off and back on really quick it does not want to start up after it is warmed up. on cold starts it fires up with no problem when i turn it on and off its just when it gets to regular Operating Temp I have my datamaster file if anyone wants to look at it. But when the car is started there are no problems at all it runs strong as hell.
Old Jan 24, 2009 | 11:31 PM
Kevin Blown 95 TA's Avatar
Do you have a bad coil or ignition module that is heat sensitive?
Old Jan 25, 2009 | 01:00 AM
lt1le2's Avatar
coil
I will have to recheck the coil i just bought a msd coil I will go down to autozone and buy the oem one and let u guys know
