Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel or ignition
Old Apr 26, 2009 | 12:56 AM
grimjeeper73's Avatar
fuel or ignition
it dont want to start and when it does for about 5 seconds it spits and sputters but never dies and after that it runs just fine it has 70 thousand miles on it and im guessing that the plugs are original i replaced the fuel pump because it went bad now im thinking fuel filter or sparkplugs or if any one has had this problem and has anyother thing to mention that would be nice b4 i waste my money thanks
Old Apr 26, 2009 | 09:30 AM
bobdec's Avatar
Pick up a fuel pressure gauge for $20-25.00 to eliminate fuel delivery causing the problem. Also could be a fouled plug, or bad plug wire that clears up after running. Or a leaking injector dumping fuel into a cylinder when it sits for a while.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
