I plan to install flow matched injectors rebuilt in Cumming GA.
My dyno tuner said my stock 24 lb 's were maxed out. Rear Wheel HP was 358 and I bought some rebuilt 34 lb ones. Will the car run? Can i make it to the Dyno tuner 55 miles away? Will it run with stock fuel pressure around 34 or should I cut the pressure back. Will the stock pump be stout enough? How will it perform after the swap before I get it tuned?
You would have to drop the fuel pressure to 23psi to make the 34's flow like the stock 24's. Don't complicate things - do what Kevin said. Drive it at the stock pressure with the 34 #/HR injectors and you will probably destroy the rings.
10-31-2016 11:09 AM
