Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
95 LT1 fuel pump electrical connector
Old Sep 28, 2009 | 06:14 PM
Danny McAdams's Avatar
I have cut the door to access the pump, how do you unplug the electric connector, it's yellow kinda U shaped.
Old Sep 29, 2009 | 08:06 AM
4THGEN Z's Avatar
I wasn't sure how to disconnect it either (not sure you can) and didn't want to risk breaking it so I just did the pump swap in the back of the car without disconnecting the wiring. There is a plug under the car near the fuel filter but didn't want to pull that wiring out either.
Old Sep 29, 2009 | 06:52 PM
Well it unplugs under the car near the fuel filter.
Old Sep 29, 2009 | 07:25 PM
Kevin Blown 95 TA's Avatar
Replace that yellow piece of crap with some wires running sraight through, epoxied, and a brass ground stud feed through to the sending unit - that yellow POS is a voltage drop barely suitable for the stock pump.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
Gtpguy
Jan 26, 2015 04:50 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
ANDYZ28
Dec 29, 2014 09:13 PM
