Would a 155 speedo work on a 2001 v6 camaro
I have a 155 speedo from a 99' Z28. Would it work putting it in a 01' V6 Camaro? Does anyone know how the 155 speedo can be converted to metric?
Re: Would a 155 speedo work on a 2001 v6 camaro
Caution!
When installing a new I/P cluster (on the last 4th gen's) it must be synchronized to the SIR module!
You need a TECH2 ScanTool for this!
I can give you the exact procedure if you need
ive heard that everything will work besides the tach, since the tach on the 155 speedo reads for 8 cylinders instead of 6, so it will read lower or higher.
you have to get one from the exact same year...if you have a 99, you need to get one from a 99 z28.
I did this swap in my 97 RS...everything works, except the tach which reads low...this can be fixed with a tach adapter from dakota digital. "sgi-8" or something.
I don't know about the early 4th gens (93-97) but from the posts it sounds like just the tach will be off.
On the late 4th gens (98-02) I know the speed would at least be off.
Check out this from camarov6.com. I think what "Antman" typed is true. The early 4th Gens have a tach problem, well mine anyway, the later ones shouldn't.
Rob
Rob
Jul 4, 2005 05:00 PM
