o2 sensors on a 97 camaro...SES light
Old Jul 19, 2006 | 12:10 PM
Wishmaster's Avatar
how many freaking O2's does this car have? my SES light is on and I had it scanned at AZ...and the code was for "downstream O2 sensor bad"
which one is that? how many do I hae?
thanks
Old Jul 19, 2006 | 01:16 PM
Fierotom's Avatar
Re: o2 sensors on a 97 camaro...SES light
The 1997 V6 engine has 4 sensors!
one in each "header", one before and one after the cat......
but downstream O2 sensor bad????
I think it is the one befor the cat, but I'm not 100% sure.
have you the original error code? It's like P01xx .....
Old Jul 19, 2006 | 02:11 PM
Wishmaster's Avatar
4!!!!!...holly crap!!!!!!..and they are like $60 a piece!....damn this car!
I dont remember what the error code was..I guess I could go back and have them do it again.....they didnt know which 02 it was either....
Old Jul 19, 2006 | 02:50 PM
valter's Avatar
"downstream" should be after-cat sensor. It isn't affecting anything at all - it's for emissions control only. You may disregard this code If you will be changing it, go with delcos, bosch sucks.
Old Jul 19, 2006 | 06:42 PM
Don350k's Avatar
Or you can do what i did buy a simulator and knock the cat out =-)
Bones
P.S. you can keep the cat on also but a sumulator is around $20 alot cheaper that a 02 sensor and there easy to install anyone who understands a volt-meter can
Old Jul 20, 2006 | 12:21 AM
AlfredB18's Avatar
Likely, the O2 sensor is not bad, but you have some other issue going on that is causing a lean or rich sensor reading to appear--of which many causes there are for such events. More often than not, O2's get replaced....because people like tossing money at parts, I suppose.
Of course, no code = no help in any case.
Old Jul 20, 2006 | 02:56 AM
jonathan_abilene's Avatar
you only need 2 of em on your car
my car only needs 1 sensor and that is a wideband sensor
Old Jul 21, 2006 | 08:39 AM
Wishmaster's Avatar
well I took it back to AZ...then I wrote down the code but forgot it ....its on a piece of paper...anyways, it said (bank 1 sensor 2)....I had the guy clear the code for me...and told him i would buy the sensor later since it was $70
the SES light has not come on since!....beats me!!....
jj_burchiel
Mar 21, 2015 12:51 AM
eazyZ
Mar 1, 2015 07:12 AM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Jul 4, 2005 05:00 PM
