Check Engine Light
Old May 4, 2006 | 12:25 PM
wakebordr2006's Avatar
Check Engine Light
i've got my check engine light on and its been running really rich so i went to get it scanned and spit out the codes 172 and 175 and the computer said it was running rich too. has anyone else had these codes before? if so, what'd you do to fix them cause the mechanics were saying it could be a lot of stuff. They said start with the 2 O2 sensors, one before and one after the cat. is this correct?
Old May 4, 2006 | 12:26 PM
JakeRobb's Avatar
Super Moderator
Re: Check Engine Light
What kind of car do you have?
BTW, this doesn't belong in advanced tech. Assuming you have a Camaro or Firebird, General F-Body Tech & Info is probably the right place.
Old May 4, 2006 | 12:55 PM
sorry bout that, but i have a 1995 camaro V6 3.8L
Old May 4, 2006 | 01:44 PM
Trouble codes don't realy qualify as "Advanced Tech". This should have been posted on the "V6 Tech" forum. I'll move it there for you.
Might want to add a "signature" with basic info about your car like year, model, engine, tranny, major mods, etc. That helps people answer your questions.
P0172 = System too rich, Bank 1
P0175 = System too rich, Bank 2
Old May 4, 2006 | 01:55 PM
JakeRobb's Avatar
Super Moderator
You said your engine has been running really rich, and that the computer says it's running rich. So why would you suspect the O2 sensors, which are confirming something you already know?
Do you have any major mods that are causing it to run rich? If so, you probably need to get your engine computer tuned to work with these mods.
Old May 4, 2006 | 05:12 PM
i have a cold air intake, new flowmaster exhaust, and a new cat. the scanner thing was showing that at least one of the 02 sensors wasn't working proporly. so i'm still guessing i should replace those? and with those mods, the engine might need a tune to compansate for them?
Old May 4, 2006 | 05:29 PM
BradcTA's Avatar
No, your mods won't throw it off that bad. Yes, it could be a lot of stuff. Maybe the injectors are stuck open???
Old May 4, 2006 | 05:37 PM
the performance of the engine has been perfect. the light came on about a week ago and i had it scanned today. the computer showed that one of the o2 sensors was not going up to about 1 volt and back down to almost 0 volts. and the other o2 sensor was doing that. he also mentioned the MAF?
Old May 5, 2006 | 11:38 AM
Garcia95's Avatar
Hey man i have that problem to but the light turns on when i'm speeding. I still havent taken the car to get checked to see what the problem is.
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
