1998 V6 camaro wont do a burn out....
Old Apr 10, 2006 | 04:15 PM
MakoLS1's Avatar
Ever since I bought it, its decently quick I guess. But I can hold the brakes down and floor the gas pedal and the rear tire will not spin over one bit....... What could be wrong? My friends V6 mustang does awsome burnouts, and my V6 camaro outruns it so I doubt its a power issue...
Old Apr 10, 2006 | 04:33 PM
6SpdLT1Z's Avatar
Re: 1998 V6 camaro wont do a burn out....
Why would you want to waste your tires?
Its one thing if you need to heat up your tires at the track... I only did a burnout in my v6 camaro once, and it was a 3.4L 5 speed.
Old Apr 10, 2006 | 04:56 PM
NOS2006's Avatar
I admit it's tough to spin 'em with the 3.08 gears. I have a Magnaflow catback exhaust and custom intake system with the stock 3.08 gear ratio and it's hard to spin 'em. Sometimes when it's cold, but not always when it's warm.
I'm throwing in 3.73 gears, a limited slip differential, shift kit, a cam, pushrods, valve springs/retainers, headers, and a tune this weekend (and early next week). I'll let you know if it loosens 'em up a bit.
Oh, and I have a '98 3.8 A4 Camaro.
Old Apr 10, 2006 | 07:52 PM
Chrisz24's Avatar
Our cars are the same except for the mods your putting in and mine peals out rarely, only if I really floor it (cant rember the last time I did that)
The Torque comes up at a different time then the Mustang I guess, I wouldnt sweat over it, IMO the camaro hookes up quick and gets moving! Rarther then throw wheel spin into the mix.
Old Apr 10, 2006 | 09:11 PM
Kidcamaro98's Avatar
i have a 98 camaro A4 that had 3.08's in it (now i have 3.73's and posi differential)...when i had my 3.08's i used to light the tires up all the time cause i get used tires for free from a car dealership we do landscping for so i just burn the **** out of them....anyways even with the 3.08's i used to be able to smoke the tires up to the point where u cant see the passanger sitting next to you...it takes a second to get going but when it does they spin
the 3.73's deff. get it done a hell lot better tho
Old Apr 10, 2006 | 09:12 PM
NOS2006's Avatar
ha, In other words: Chevy did what Ford couldn't.
Old Apr 11, 2006 | 03:16 AM
jonathan_abilene's Avatar
i'd rather have a car that got traction, than one that burns out
if you had a manual it would
or if you had a torque convertor/stall
or if you hit a 50-75hp shot of NOS it would
my car is a 3.8l, It hooks REAL good, I can whoop almost all v8s off the line, because mine hooks, and does hole shots!
Old Apr 11, 2006 | 08:39 AM
2000slp2768's Avatar
Im confused. You say your v-6 cant do a burn out, yet your sig is showing a v-8?
Old Apr 11, 2006 | 08:43 AM
MustangEater82's Avatar
dunno, jack up the air pressure?
never had a problem lighting my tires up... but I have only had 5-speed 4th gens... But even then if I jump on it the wheels spin.
Old Apr 11, 2006 | 06:56 PM
450HP_V6's Avatar
Okay, i think a problrm you had when trying to burn out may be that 98 camaros come with four wheel antilock brakes. If youre holding the brakes to do a burn out, the brakes in the rear are applied also, and is probably the cause. I could be wrong though, and I'm sure i'll hear about it if I am.
Old Apr 11, 2006 | 07:23 PM
Chrisz24's Avatar
The rear discs do clamp better then the previous drums making it harder to peal out.
Old Apr 12, 2006 | 03:20 AM
95 Civic's Avatar
headers, full exhaust, cai, stock 3.42's, and a programmer.......i cant keep mine from burning out. it sucks
Old Apr 12, 2006 | 04:00 AM
Originally Posted by 95 Civic
stock 3.42's..........i cant keep mine from burning out. it sucks
get a posi then
Old Apr 12, 2006 | 06:20 AM
that is true... but you can still roast them...
Old Apr 15, 2006 | 02:49 PM
PaganEgyptian's Avatar
Post Re: 1998 V6 camaro wont do a burn out....
mashing your brakes too hard will prevent you from breaking the rears loose. This is an easy fix with a line loc. -Tim
F'n1996Z28SS
Aug 23, 2023 11:19 PM
hotrodyou1
Dec 20, 2014 10:05 PM
Klypto
Jul 24, 2002 11:21 AM
Klypto
Jul 24, 2002 09:38 AM
Klypto
Jul 19, 2002 07:25 AM
