What type of oil?
Old May 31, 2006 | 04:57 PM
fesgali's Avatar
What type of oil?
I know it says to use 10w30 but i feel like it doesn't stand up in the summer heat. Would it be safe to use a higher rated oil?
Does anyone use anything other then 10w30?
Old May 31, 2006 | 05:36 PM
94Camaro's Avatar
Re: What type of oil?
10w30 should be perfectly fine for summer heat. i use it here in California. Mobil-1 too
Old Jun 7, 2006 | 10:51 PM
gweedo1287's Avatar
I run 5w-30 in my 94 3.4 liter. I ran 10w-30 in it for one oil change and noticed that it ran a lot smoother with the 5w-30 in it. As far as summer heat goes it should be fine with either one.
Old Jun 9, 2006 | 04:05 PM
Tru2Chevy's Avatar
Switching up to a 10-40, or even a synthetic 20-50 is perfectly fine in the summer.
- Justin
Old Jun 11, 2006 | 09:00 PM
Chevamaro's Avatar
I think it's the temperature inside the engine that's most important. My cooling system keeps it in check. Not trying to be a smartass here, but I seriously doubt the ambient heat changes things enough to need a different oil.
Old Jun 12, 2006 | 03:39 PM
Tru2Chevy's Avatar
The reason you don't want a real thick oil in the winter is that it will take longer for the oil to be pumped through the engine when you start the car. The longer it takes for the oil to make it throughout the engine, the more wear occurs.
Synthetic oil usually flows better than conventional oil of the same weight in cold temperatures, so you can run a "thicker" or "heavier" synthetic in colder months to keep your engine protected.
- Justin
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
FredM
Jun 5, 2015 05:45 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
alex5366
Apr 1, 2015 09:27 AM
