95 V6 vs Z28
Old Aug 26, 2006 | 06:51 PM
CamaroGuy22's Avatar
95 V6 vs Z28
I was thinking about buying a 95 Camaro for parts. What part differences are there between the two other then the obvious motor 3.4/3.8 vs 5.7. Do they use the same front suspension set up and k-member? What are all the differences.
Old Aug 27, 2006 | 10:24 AM
AlfredB18's Avatar
Re: 95 V6 vs Z28
Outside of engine and tranny, the v8 car rear has discs, but the rest of the rear axle is the same. Suspension, if not the same, is really similar in terms of stuff like swaybar measurents and the like...
K-member is different for all 3 engines mentioned. The rest of the sheetmetal and subframe is the same. The wonders of mass production.
Old Aug 29, 2006 | 09:27 AM
2000GTP's Avatar
Re: 95 V6 vs Z28
I would venture to guess that the spring rates would be different as well as alot of the v8 guys swap in the v6 springs in the front for track purposes.
Old Sep 4, 2006 | 06:38 PM
1995greenTA's Avatar
Re: 95 V6 vs Z28
V8 cars arent one wheel peel...so im assuming there is more different in the rear end other than the disc brakes
Old Sep 4, 2006 | 10:11 PM
MustangEater82's Avatar
Re: 95 V6 vs Z28
Its just the differential, and the brakes, and newer v6s 4 wheel disc brakes were standard.
they are the same...
differences off the topf my head...
motor
tranny
kmember
tranny brace
spring rates(some v6s are stiffer some are softer)
motors
fuel pumps
fuel lines
exhaust
the rears are the same but most v6s had open diff, some had LSD (option G80)
Old Sep 5, 2006 | 09:38 AM
AlfredB18's Avatar
Re: 95 V6 vs Z28
Fuel lines....the v6 ones can be used. Supposedly just undo the clip holding the v6 ones in place and stretch to the LT1 intake.
Fuel pump, yeah, different, but will more than get you by unless you drag race the car. I just want a cruiser that I don't have to shift gears on. That works.
You can get by with v6 springs, you could get by with v6 exhaust piping after the exhaust manifolds if need be. I already have a Z-car catback in storage.
If I'm waaaay off, I'll find out after I go drivetrain shopping. Bet on it.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Renegade Toker
Jan 23, 2015 10:27 PM
NewsBot
Jan 11, 2015 06:10 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
