NEED help !! engine hellllp!
Old Sep 8, 2006 | 11:21 PM
justin90chevyz71's Avatar
ok like it says i need help with my v6 camaro .. i just bought it last week and i was told that 3 cylinders have low compression.. what i need to know is how to fix this problem ,so any help is greatly appreciated
thanx
Old Sep 9, 2006 | 06:24 AM
M5camaro's Avatar
Re: NEED help !! engine hellllp!
I guess I could be way off on this, but doesn't that mean that you need to rebuild your engine? Or at least change head gaskets and such?
Old Sep 9, 2006 | 08:25 AM
Fierotom's Avatar
there are many reasons for low compression!
are the three cylinders at the same bank?
try the search function and you will find many descriptions how to find the reason for low compression.....
If you spray a little bit oil in the combustion chamber and makes a new compression check and the pressure goes up you have bad piston rings...(for example) If not, you have a problem with the head, maybe valves or the head gasket or in the worst case a cracket head
Old Sep 9, 2006 | 12:23 PM
MustangEater82's Avatar
imo... if its a tired motor you could honestly jsut buy a new(used) motor and drop it in for cheaper then fixing yours, if its anything more then a bad headgasket.
I have seen lower mileage 3.8Ls go fro less then $500. a full rebuild, ring replacement, or even head work will cost more then that.
I almost picked up a 3.4L once for $100
Old Sep 9, 2006 | 02:57 PM
NOS2006's Avatar
I'll agree with that. I've had the experience of rebuilding my 3.8. Not fun nor cost-worthy.. should've gotten an LS1.
Old Sep 11, 2006 | 12:31 PM
the motor only has 75000 orignal miles on it and i am going to do a ls1 swap on it. i just wanted it to get running right so i could drive it untill i get the motor
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
centric
Aug 15, 2002 09:04 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
