View Full Version : Drag Racing Technique
Pages :
10
11
12
13
14
15
16
17]
18
19
- TH400 Questions
- HOLESHOT techniques.,I need help
- What's you plans for next year??
- Info on contingency money
- On The Jenny Craig Program This Winter: -700lbs
- Sooo, I yanked out my a/c, weight reduction #'s within
- auto-meter shift lite ?
- Who has switched from an LT1 to a standard SBC?
- Want to get my times where they should be...
- 245/50/16 vs 275/40/17 drag radials
- t-700 any good
- Who exceeded/met/fell short of their '02 goals?
- Need Advice for Next Season At The Track
- Where yo buy a bare 9" housing
- what is you best 60ft on street radials....
- vibes
- New times for the 91 RS!
- To FLASH or not to FLASH the TC???
- I give up on 11's
- Are aftermarket shocks, springs and other suspension parts really worth it?
- Single or dual driveshaft safety loops ?
- street/strip springs and shocks?
- Drive shaft safety loop...which one
- Launch techniques needed real bad!
- Largest size nitto DR for 16" rim.....
- Drag with the speedometer?
- New Best!
- Track tomorrow.. wish me look to get into the 12's..
- practice trees
- John Lingenfelter update
- cheater slicks
- a warning about my recent dealings with Yank
- 1 5/8 or 1 3/4
- Whats Your Water Temp At When You Bring It To The Lights?
- which springs for me?
- Shock/Spring Decision Time
- Drag Racing Video.
- Mech or Elec gauges
- M/T tire's
- Track Video
- Just got back from Track with my '01 Z
- what should i run in quarter???
- Barometric Pressure
- You boys won't believe this 9.66@134mph!
- fastest stock A4 LS1?
- Need Help building my fuel system
- Lca Relocation Brackets For Stock Rearend????
- 1/8 mile times???
- ARE K-Frame A-Arm Sale
- Heads and Cam LS1
- Baton Rouge LS1's ???
- Anybody using adjustable KYB shocks for drag racing?
- Rollcage Information...
- 1/8 mile times with stockish lt1's
- traction bars vs LCAs
- tire size?
- Anyone planning on going to LS1Tech events?
- Tire choice...... please help
- 12-Bolt vs 9"
- Check this out...FREAK Z06:-)
- first time at the track.. have some ?'s
- 11s With Stock Stall And 2.73s??
- Anybody In The VA Area, Going To Colonial Beach........
- Are they Worth it?
- Update on SFI certified T56 bellhousing
- suspension changes
- 10.98@121.44 Cam Only!
- New best...10s NA ..will it hapen. a bitter sweet story
- New best..... inching closer to 11's with Bolt-Ons!!!
- lockup-vs-nonlockup...which is best for racing?
- New stockhead best!
- Newbies To dragracing
- shift light suggestions???
- Expected better ET's - advice wanted
- A4 LT1 1/4 mile
- Another New Best = 6.111@113.63
- 1/8 vs. 1/4 mph and how it relates to tires
- Anyone cutting 1.4 60' or better with BFGs??
- Launching on 4.10's
- T56 HP levels
- Honest Opinions, How Fast....
- C4 -vs- TA
- What should my ET's be?
- wheels and tires???
- subframe connectors and crossmembers
- Power Steering removal???
- Drag Race Header
- Not really a racing question but...
- How can I get low 12's ?????
- Anyone ever try this?
- Expecting 12-flat E.T.'s --> What Driveshaft Do I Need?
- Open headers
- M6 to Turbo 400 conversion
- Installed FTRA on my SS
- Spec Stage 4 longetivity...
- tires????????
- Where do you M6 LT1 guys shift at?
- Hit the 12's with bolt -ons last night. Time slip inside....
- How much 60ft will i gain going to Hals front and rear
- Cooling fan control techniques
- Well if i could drive....what can my car run???
- Track Results
- Drag Racing
- North vs. South F-Body Shootout May 31st 2003 Beech Bend
- Gearing and Tires for 1/4 Mile
- opinions on launch techniques...
- How much speed are you gaining after the 1/8 mile?
- Finally made it to the track after 3 years
- 9.841 @ 137.41 and More to Come!
- Anyone pickup with a t-brake?
- New best, 6.600@104.84
- Guy's running 9 inch rears.......
- drag racing suspension?
- Bolt-on New Best 11/4
- Anyone running 11's on street tires?
- TH350 or built 4l603e?
- New best!! Kinda good but kinda crappy
- Almost 12's.....stock!!!!
- new best 10.012@135.95 n/a
- New best w/o the CSI.
- Woot! First 1/4 times!
- Battery relocation
- Pinion angle
- track day
- stock times...
- LT1/LT4 Guys, Whats Your Race Weight?
- got a drag question...
- What RPM on factory Tach?
- Stock 94 z
- new best for my "real" pontiac
- Looking for tips - Running KDWs at the strip
- For those using airbags in the suspension.
- If I am trapping 102 now...where will I be after the True Duals go on?
- Congrats WickedTA, Nice Front Cover!!
- Safe weight reduction?
- Expecting traction problems - Please read!!! Need Help!!!
- Toro Intake!!!!!!
- East Coast Nats Heads Up Class Suggestions?????
- Hoosier QT Pros vs. MT ET Street Results!
- CC306 Times with STOCK HEADS...
- best auto shifter for 4th gen
- stock rear end
- Quick Fuel Technology
- Looking for a 50/50 weight transfer.. Any advise?
- Anyone wanna guess numbers on what my 305 TPI N/A will do
- Bad track times....
- th400 tranny mount and other questions
- new best at drlington shootout
- Street twin + Nittos = BOOM!
- How does my time look
- Please help! Take a look at my et/mph.
- new best=6.16@110
- New Best MPH (and stree tire E.T.)
- First trip to the strip
- Who's got the fastest n/a Lt1...
- New times but, E.T.-M.P.H. off, what do you guys think?
- What do you think I would run?
- holy cow...
- Drag Racing Insurence?
- Update: SFI T-56 Bellhousing
- 9 Sec. LT1 Street Car vid!!
- How do you get the shoe polish off of your car?
- Times Question
- Crazy Question
- Stock Style Suspension Rules
- What is D.A.?
- drag + handling suspension?
- To those who have installed a Wolfe Bolt-In Rollbar...
- Guys with Hossier QTP's?
- Second Time at the Track with my 96 TA what do you think?
- Potential for LOWER ET's
- gearing question... crossing the line at top of 4th at 103
- Does this ET and trap speed seem off?
- New powerglide in..... results....CONFUSSION!!!
- TH400-should I get one, where to buy?
- Another best for Jason Warren
- Should I lock my converter or not?
- Track results with single turbo IROC
- Ill effects of lowering on 60 times, Front Vs Back
- Video Passes at Thunder Shootout
- Darlington Nov 16
- Northern F-body Shootout Spring 2003
- questions about the high stall/obd1 issues
- Ladder Bars with a wishbone.
- Another Turbo 350 swap question
- New times for me.
- New best...
- New LT1 Bolt-On best again tonight.
- Traction, HELP!!!!!!!!!
- Nitrous & Vert
- Bogart wheels
- gear and times question
- Calculating rwhp?
- New Best at Maple - 9.97 @ 135
- Why are my times so low??
- New Best @ Southern Shootout!
- Lowering car and new shocks, help times any?
- Subframes and Traction
- tire height and spring ???
- Thanks to THUNDER RACING for reviewing thier decision
- Are GeForce 315s too much rubber for slightly modded SS?
- new best for WS6
- A couple insane cars at the track yesterday, and a new best N/A for me
- Pass tech with swingouts and cage?
- some new times! opinions?
- Congrats Z-9s...New Best
- Thunder Racing Southern Shootout Results
- lookin fer 10's
- 10.06@133.72 n/a 1.40 60ft. footbraking
- Anyone with pics of S&W Rollbar??
- Another New Best.
- Turbo 350 swap question
- New best at SCD and Thunder Shootout!
- New best @ Thunder Shootout...
- Any results from Thunder shootout
- another possible 9 sec n/a lt1
- New Best at thunder shootout..11.03 at 124.25
- Attn LT1 Big Dawgs 9.90 and Faster, Enter If You Dare
- which suspension parts help and which hurt
- Fastest 4th Gen Stock Style Suspension
- BF Drag Radials
- need advice on launching with nitto dr's
- batt on/off switch neccessary?
- 2nd time at the track.
- 1st time to the 1/4 mile!!
- rear spring airbag question
- Anyone with a built 3rd gen
- bmr trak pak vs. spohn torque arm
- T56 to th400 swappers---which trans cooler to go with?
- New track times
- need advice on spring rate / height for a good drag / street compromise
- Season Closer...Third round showing
- All cam only LT1 guys post your times and mods here...
- Is it necissary to do a burn out with street radials?
- Which wheelie bars are the big boys runnin'
- new track times
- I did it..I did it! I learned how to drag the M6...new times
- ARE Camaro Goes 8.92@152mph
- anyone running Eibach Drag-Launch Springs?
- I'm pumped up...
- Nitto's vs. BFG Drag Radials!
- Finally raising stall to 3200...what should I expect?
- Launching a non-posi car
- Darlington, SC on 11/16
- Lower control arms needed with Nittos?
- Launching a bolt on LS1
- new 1/4 times for Jason Warren
- What 60 foot time, 1/8 MPH and 1/4 Mile Trap Speed to you need to run a 12.99?
- Do I have what it takes to get into the high 12's?
- New pics of Madmans Camaro
