New stockhead best!
Old Dec 7, 2002 | 12:17 AM
Frank95z's Avatar
New stockhead best!
From the beginning my car is a street car with a/c,power steering,power brakes not a stock eliminater car.With DOT tires all the way around. It weighs 3420 with me in it. It has stockheads,and stockbottomend and NA , No spray no blower. Tonight in good air in South Louisiana I ran a best of 11.53 at 115.53 with a 1.51 60ft. That was a best for me. Frank95z
Old Dec 7, 2002 | 12:54 AM
kcsoz20's Avatar
Thumbs up Wow! please detail what yu have done
Here are my mods;
BBK 52 mm throttle body, ported MAF ends, K&N CAI, ASP Pulleys, 160 thermostat, PCM by WWW.PCMFORLESS, LT4 KM, Heads by WWW.flow-technics.com, 2.055 int/1.57 exh. valves, 1.6 RR's, CC XE 230/236 544/556 112 LSA, Comp "R" lifters, Comp Magnum pushrods, FMS 24# SVO injectors, Meziere WP, Jet Hot coated Hooker LT's, Flowmaster cat back exh., PI Vig 2800-3000 TC, Strange 3.73 gears.
Please detail what you have done to get 11.5x's. My best is 12.0 @ 113. I probably need a dyno tune and I am running on stock suspension.
I just wanna 11.xx time slip!
Ya running a 100# roll bar/
Ken
Old Dec 7, 2002 | 01:21 AM
Frank95z's Avatar
If you would check www.thunderracing.com customers cars my name is Frank Benoit there you will find a list of mods. I will say that it appears that you and I have similiar cars except you have ported heads. Yes I have a 110# mild steel rollbar. I run at a sealevel track and ran my new best in these conditions 45 degrees,56% humidity and 30.37 baro for a DA of -1330. Your 60 ft seems to be were your problem is. I ran a 1.51 shorttime tonight. I have a Vig3200. My suspension is stock also but converter hits right below peak torque on my car. Good Luck Frank95z
Old Dec 7, 2002 | 05:28 AM
kcsoz20's Avatar
Thumbs up Thanks Frank!
My best 60 was a 1.67, but I did not get my best E.T. out of that.
I bet I could use a restall on my vig up to 3200. Just gotta deal with the OBD1 issue. It has hit me twice this year.
I think a good dyno tune would help too. I have Bryans tune from PCMforless. No complaints on that tune. Very good for a mail order tune.
Ken
Old Dec 7, 2002 | 07:31 AM
Frank95z's Avatar
If you can get the dyno tune first to determine where you're making peak torque. With the larger cam and ported heads you may need more than a 3200 to get to where you're making the most torque. Just an idea. Frank95z
Old Dec 7, 2002 | 08:15 AM
big dave's Avatar
Wow, congrats Frank. I can't think of a more impressive lt1. What kind of power are you making with that cam? I dynoed my heads/cam combo and with my newly restalled 3200 vig, made 416 rwtq at 3500 rpms.Unfortunately I have several bad valvesprings so my rwhp is down by 26 horses to 320. I too thought a heads/cam car would make peak torque around 4k but mine wasn't even close. A 1.51 is excellent for such a small converter. What tire are you using? What gears? What have you taken out of the car to get it that light? Mine without front swaybar, passenger seat, and with skinnies still weighs in at 3460 without me. Once again,
Old Dec 7, 2002 | 09:31 AM
Frank95z's Avatar
My car is a hardtop,standard radio,cloth seat Z28. I have no front or rear swaybars,no rear seats,last night I had no passenger seat. I run two header mufflers for exhaust But I do have stock carpet with padding removed,all panels,console are in place. I still have a/c,power steering,abs power brakes,airbags and bumper supports. Added weight is a Strange 12bolt and mild steel 110# rollbar. For some reason my car has always been a freak about weight. It was a GM program car in 1995 titled to General Motors, Detriot,Michigan. I run 3.73 gears and 27X11.5X15 Hossier QTP's on Convo pro wheels. Fronts are Centerline Warriors with MT street fronts. Car still gets 25mpg on highway and was driven to work everyday from 1995 til March of this year. Now its a weekend car mostly. I still like the looks when I pull up to the traffic light with rolbar and 5 point harness Car has never been dynoed I don't want to find out that I only make 280hp and the car to slow down to 13's Good Luck Frank95z
Old Dec 7, 2002 | 10:19 AM
96z's Avatar
96z
Very nice Frank.....putting us all to shame.
Old Dec 7, 2002 | 10:49 AM
SAR2K's Avatar
Thumbs up
Awesome runs last night Frank!!! And congrats on taking the 1st place tropy home last night in the brackets!!!
Steve...
Old Dec 7, 2002 | 11:09 AM
Ken95Z28's Avatar
Frank, dang it, just when I think I'm getting closer you still keep pulling away.
I wish I could get the good air up here.
Congrats on the run!!!!!!!
Old Dec 9, 2002 | 10:36 AM
dougg01's Avatar
Congrats Frank....
I finally got tired of messing around and just installed a yank 3200 and a 'good' program. Now I have to wait for the spring thaw to find out what it runs. Oh, and it's still the daily commuter.
Old Dec 9, 2002 | 11:48 AM
T/A lt1's Avatar
Frank I don't know what you are doing but that car is running fast. I want to go that fast but my car is 3700lbs and I can't 60' for ****. Anyway I will keep trying. Later Clint
Old Dec 9, 2002 | 07:48 PM
Frank95z's Avatar
Thanks guys I work on a lot of little things on my car and they add up. I'm really running tires that are to tall right now I'm running 27x11.5x15's with a 3.73 gear. I am not going to do it right now but I'm planning on a weight reduction program to lighten the car 120#'s and a tire x gear change. I think I can run high 11.30's. I predicted 11.40's or 50's this year and reached it. Anybody want to bet on 30's. Frank95z
dalynchmob
Mar 31, 2013 06:06 PM
thunderkyss
Sep 26, 2012 08:45 PM
2MCHPWR
Oct 17, 2004 07:21 PM
Frank95z
Dec 31, 2003 01:47 PM
Frank95z
Jan 24, 2003 06:58 AM
