vibes
Old Dec 23, 2002 | 12:40 PM
dougg01's Avatar
vibes
Okay, so since I have broken two 1LE tranny mounts (2nd afterI added my relo brackets ) I've switched to a ES poly unit. I've not got to make a pass in 6 months with all the suspension working.
Vibes galore. I knew it would happen since I still have the stock DS (new joints).
Here's the weird part....the vibe varies.
If I launch soft and roll on the throttle the vibe is liveable.
If I launch hard or drive normally...it can shake pretty bad, however, this is not a constant nor repeatable.
There are times the vibe is almost undetectable (back to the feel with the rubber mount). I have checked for alignment and everything looks okay. If I get time I will check my pinion angle and see where things are.
This is getting annoying on the commute (60-70mph can be quite shaky) and I know all that vibe isn't good for my drivetrain.
Ideas....? The u-joints are tight and properly seated. I can borrow a 3.5" LPE to see if that clears things up. I'm wondering why the affects (if it is the DS) seem to vary so much or if I need to look elsewhere (the pinion and bearings are tight).
thanks.
warmeck
Jul 17, 2015 01:36 PM
formula79
Feb 15, 2004 09:10 PM
Darth Xed
17
Dec 7, 2002 10:30 AM
floorpedal1
Oct 16, 2002 07:42 AM
