What should my ET's be?
I've got a 95 TA with cat-back, Stage 3 Clutch, cut open air box, 1LE elbow, TB airfoil and bypass. What kind of times should I run with street tires on 1/8mi and 1/4 mi? I've done a run on 1/8th and had best run of
2.30 - 60'
6.19 - 330'
9.30 - 1/8
79.35 mph
I ended up realizing later that my runs were done with a chewed up differential (3 teeth were broken on diff)
Is this time normal, what should I run 1/4mi?
2.30 - 60'
6.19 - 330'
9.30 - 1/8
79.35 mph
What would you suggest for next mod to put me in 13's 1/4 and 8's on 1/8? I'm getting alumin driveshaft by next week (if I can find a used one) I considered underdrive pulley as next mod, then either 1.6 RR and HD valve spgs, Ram Air kit, or longtube headers and no cats or cutout. Would 3.73 gears help?
