another possible 9 sec n/a lt1
Old Nov 2, 2002 | 11:28 PM
Joseph Overton's Avatar
first pass on new setup n/a
10.99@130.4
7.21@104.84
1.78 60 ft. car had nasty bog out the hole
a lil tweaking
10.87@130.2
7.08@103.23
1.71 60 ft.
still bad bog off line
racers opted to go 1/8 since track conditions were getting chancy
finally getting most the bog out it went
6.53@105.63
1.46 60 ft
lil more tuning and
6.46@106.32
1.43 60 ft
nearly 6 1/10's improvement over the 10.87 pass in the 1/8 and 3 mph..utilizing 4.11 gear set and 28x10.5 tire and footbraking shifting at 6900...All things considered it should be a verly low 10 if not a high 9 sec capable setup in the 135 mph range... Gonna give it a shot tommorow with most the bugs worked out and see how things change through the whole 1/4..
Old Nov 2, 2002 | 11:50 PM
kevkop94TA's Avatar
Thumbs up
I hope you get it Joe. Let us know how it goes.
Old Nov 3, 2002 | 01:46 AM
cenman's Avatar
Exclamation
great times. it sounds like a very low 10, from the 1/8 mile et. a little tweaking here and there and 9's should not be a problem.
why was it bogging so bad?
Old Nov 3, 2002 | 10:55 AM
RacinLT1's Avatar
Joe,nice times......got that thing moving in the 1/8.
('s shouldnt be too far away..then spray the snot outta it.
Old Nov 3, 2002 | 11:01 AM
Jason Short's Avatar
Impressive Joe! Its nice to see some fast NA LT1's!
What is your combo consisting of now? Also, what intake manifold are you using?
Thanks, Jason
Old Nov 3, 2002 | 01:23 PM
chevyguy3's Avatar
Awesome
i was happy just to run 10s NA today
DirtyDaveW
Dec 1, 2016 05:37 PM
eazyZ
Mar 1, 2015 07:12 AM
blac94Z
Dec 2, 2014 12:09 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
WIKIDTA
Aug 12, 2002 12:57 AM
