Anyone pickup with a t-brake?
It adds consistancy since you can launch at the same rpm every time. It also will allow you to launch at a higher rpm than the car's brakes can hold or what just a 2 step can go to.
My converter will stall to 5700 on the transbrake but I only launch at 3000 rpm off a 2 step.
Don't forget that if you use a transbrake like this you'll need to beef up the rest of the driveline. I use a steel 3" x .083" driveshaft with 1350 series u-joints and a 9" diff.
mlopezart
Sep 8, 2015 12:15 PM
