Anyboby have a problem with a factory alarm?
Old Oct 25, 2002 | 03:49 PM
ZZed's Avatar
Angry Anyboby have a problem with a factory alarm?
8 seconds after arming, the alarm goes off. It is a problem with the shock sensor circuit. It happen last winter. I had to disable the sensor until the dealer replaced the shock sensor, all was fine. This time around, it stopped after I shook the wires. I know its the shock sensor circuit because the car honks twice when I disarm it. By the way, the dealer I took it to was incompetent,so I can't trust they found the real problem to begin with. Any insight would be appreciated.
Old Oct 25, 2002 | 11:10 PM
BlueLS1Z28's Avatar
i have the same problem waiting for answers to roll in
Old Oct 28, 2002 | 12:55 AM
BlueLS1Z28's Avatar
ttt
Old Oct 28, 2002 | 01:52 PM
white97T/A's Avatar
yea I had this problem lately too. take the sensor apart and see if it has water in it. mine did
btw all you need to do to take it apart is cut the zip tie off and then pry it apart with a scredriver or a dime or something
oh I dried mine out but have not reinstalled it so I dont know if it will work again or will have to be replaced either way this is likely your problem
Old Oct 28, 2002 | 03:41 PM
ZZed's Avatar
BINGO!!! I did that on Saturday. The circuit board is fried. A new one is $32. The water rolls down the hatch when opened and finds its way into that area. 2nd time for me. I'm fixxing that before I fry another sensor. Any ideas? I'll let you know what I come up with. For now, I programmed the alarm to ignore the sensor.
Old Oct 28, 2002 | 03:57 PM
DohHunter's Avatar
Wink
Solution, don't wash your car or drive it in the rain
Like me
Old Oct 28, 2002 | 04:18 PM
96fbirdA4's Avatar
Try the plastic baggie mod. Works every time
Old Oct 28, 2002 | 05:44 PM
white97T/A's Avatar
zed explain what you mean about programming to ignore the sensor. I have mine out of the car right now and am having no problems.
Old Oct 29, 2002 | 11:30 AM
ZZed's Avatar
The owner's manual tells you haw to customize certain features of you car, including the alarm. It involves removing the radio fuse, turn the igniton switch to acc, and switching things on and off. (The manual is clearer than I am.) I don't like leaving wires unplugged, especially whee water is known to reach. I don't know what year the BCM (body control module) became programable. Check your manual.
NAVY99
Oct 3, 2002 03:47 PM
Rich_z28
Sep 13, 2002 03:35 PM
JSK333
Sep 9, 2002 10:33 PM
SVT3852
Aug 16, 2002 03:35 PM
dreamer1q
Jul 24, 2002 04:39 PM
