How do I replace the turn signal lens?
I just did that yesterday. I put the clear turn signals in. I took off the skirt under the front nose, jacked the car up, and took it off that way. That was the hardest thing I have ever done with my car. Its not a problem getting to them or unbolting anything, its getting around that foam in the nose cose. Maybe I did it the wrong way but thats how I did it. You could probably unbolt the headlight and go at it through the top...it might be easier that way.
Like stated above... 1 bolt holds the lamp housing in.
It is 10mm and is dead center on the rear of the housing. Unplug the bulbs first! Then remove the bolt. Slide the lamp housing towards the nose of the car, then lift it out. Easy.
Now look down into the hole, the corner lamps are right there for the world to see.
Good luck
Dave
Good luck
Dave
stangspank
Nov 13, 2015 01:02 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
