17x 11 rubbing inside of wheel well
Ihave 17 x 11's on the back of my 2000 Transa AM,
Just put the SLP level 1 suspension kit, lowered it a little, but now on hard turns the inside of the tire rubs the wheel well..
Any suggestions on what to do...
Should I bang the wheel well in a bit or have it cut and squared off?
Thanks All
Thanks All
an adjustable panhard bar will fix this and put your rear back into center
when you lowered your car the rear moved off center...hang a nut from a string and hang it over the rear wheel well opening and check the distance between the string and the center of the wheel...(check both sides) if its off by more then an 1/4" you need an adjustable panhard bar
good luck
(TW)Sabbath
good luck
(TW)Sabbath
squarehead
Nov 21, 2014 08:02 PM
