Check Engine light
Old Nov 5, 2002 | 10:31 PM
dgordon98's Avatar
Check Engine light
Hey I had to put on a gasket on my exhaust manifold, when i took the cat off I accidentally broke two studs off so I had to run the car with a exhaust leak for a day untill I could get it sealed now the check engine light stays on, theres no leak. What can I do
Old Nov 5, 2002 | 10:45 PM
IrocSS85's Avatar
Re: Check Engine light
you need to clear the code(s). it wont go off by itself. it will set a lean exh. code. as well as some others like O2 codes.
chris
Old Nov 5, 2002 | 11:00 PM
dgordon98's Avatar
reply
Dont want to ask a dumb question but how do you reset the codes?
Old Nov 5, 2002 | 11:38 PM
SpecForceZ28's Avatar
Re: reply
Not a dumb question at all, but heres your answer:
http://www.installuniversity.com/ins...am_air_mod.htm
somewhere in the beginning of that it tells you how to reset it. Enjoy
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
