Detailed instructions needed on how to remove the low coolant sensor !
Old Nov 5, 2002 | 04:32 PM
NEWBIE T/A's Avatar
Lightbulb Detailed instructions needed on how to remove the low coolant sensor !
It's time to pull the little bugger & either clean it or replace it as when the coolant is cold, the light comes on, but once it warms to about 1/4 gauge I can restart the car & the light goes off ...
The fluid level is fine, so I know it's just doing it's thing again !
In any case, I did a search with no luck - the closest I came was the actual P/N from here:
http://web.camaross.com/forums/showt...COOLANT+SENSOR
I think that if you pry the little wire snap clip off the sensor it will slide out, but would rather be safe than sorry !!
Thanks in advance !!
Britt
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
