Idling at 1100...Isn't that too high?
Old Nov 3, 2002 | 12:40 AM
therealmagyver's Avatar
I have a 98 z28 6spd idling at 1100. I only had the car 2 weeks. What vacuums should I check? Or is there something else I need to be aware of?
Old Nov 3, 2002 | 11:28 AM
racehead's Avatar
That's definitely too high unless it only does that when you first fire it off in the morning. If it's happening when it's warmed up then there's a problem. Check the throttle cable for binding and listen for vaccuum leaks etc.
Old Nov 5, 2002 | 10:57 AM
DarCwuN's Avatar
I have a 98 Z which also idels around 1000-1100 i just thought it was normal for the Ls1. What is the normal idling rpm
Old Nov 5, 2002 | 11:14 AM
bbentley40's Avatar
Mine is around 1000-1100 when I first crank it.. but after warming up it stays around 800 or so.
ad356
Apr 11, 2015 08:49 AM
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
ChrisFrez
Mar 1, 2015 01:33 PM
IRABuss
Sep 7, 2011 09:08 PM
