Delteq with LM1 Wideband rpm help
Old Aug 22, 2011 | 08:52 PM
RACEON's Avatar
I have tried LM1's recommendation from their manuals to get rpm to work using the LM1, rpm cable and inductive clamp. RPMS are all over the place.
Who here has actually got this cocktail of crap to work for you to get AFR and RPMs together.
And please, no get rid of the DELTEQ options
Old Aug 28, 2011 | 02:20 PM
RACEON's Avatar
SOLVED: Delteq with LM1 Wideband rpm help
Update:
The inductive clamp doesnt not work due to saturation/waste spark type coils.
So, I finally tapped off the Delteq module to get an RPM signal from the tach output coming from the ignition module. Then you auto config the rpm converter cable at the 2000rpm till it picks up proper timing.
So all in all, persistence pays off.
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
tommalcolm
Sep 11, 2015 03:39 PM
