LT1 MAF Readings -- What should I expect?
Old Feb 3, 2012 | 02:24 PM
tylerwerrin's Avatar
Hi guys,
I'm still having little pops in my exhaust pipe, which i assume is either a rich or lean mixture problem. I've replaced the plugs, wires, coil & opti during a recent tuneup to try and resolve the issue. However, it's still present.
I haven't changed the O2 sensors yet either -- but I read that the MAF can cause strange symptoms that I was having before the tuneup (missing, stumble on acceleration, poor idle, the popping, etc.)
What are the MAF readings that I should expect when I patch in with TunerPro or Datamaster? If i can determine the MAF is OK, then at least I can focus on other possible problems (like the O2 sensors...)
Can anyone help?
Thanks!
1994 Camaro Lt1 w/T56
Old Feb 3, 2012 | 03:18 PM
Re: LT1 MAF Readings -- What should I expect?
At idle, you can see anywhere from 6 - 10 grams/sec. At WOT, the max reading will depend on your modifications. Stock, at sea level you might see 240 - 250 grams/sec.
Old Feb 3, 2012 | 07:38 PM
Thanks injuneer -- once I can find another copy of DataMaster with more trial runs i'll see what the readings look like.
Old Feb 4, 2012 | 01:08 PM
WS6T3RROR's Avatar
The wot readings will be temp dependent.
DirtyDaveW
Dec 1, 2016 05:37 PM
cmdeshon
Jan 4, 2015 11:15 AM
formula218
Dec 2, 2014 04:27 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
