speedometer help
Old Jul 17, 2011 | 02:24 PM
sk101400's Avatar
speedometer help
i have 94 Z-28 A/T and speedometer picks and chooses when it wants to work.
anybody with any ideas what's going on??????
Old Jul 17, 2011 | 10:28 PM
Re: speedometer help
You may have a faulty vehicle speed sensor (VSS) on the tailshaft of the tranny. If you do, it will set a code - have you scaneed it for codes?
If there is no code for the VSS, the signal is consistantly reaching the PCM, so the problem would be the wir from the PCM to the cluster, or the speedo itself. Does the odometer still work, when the speedo stops?
Old Jul 19, 2011 | 05:22 PM
sk101400's Avatar
no codes are showing up.
yes, the odometer is still working even when speedometer is not.
Old Jul 20, 2011 | 05:24 AM
I''d say you need a new cluster.
LazyLemming
Aug 29, 2015 07:36 PM
nosliw
Apr 27, 2015 04:01 PM
mattstrike
Mar 12, 2015 10:12 PM
red
Apr 6, 2003 08:02 PM
Michael Ozorowsky
Oct 2, 2002 01:58 PM
