lc 1 logging
Old Jul 1, 2012 | 01:16 PM
SCREAMING Z's Avatar
lc 1 logging
HI ALL i got my wide band hooked up so i can log my lc1 but i want to know if there is a way to get the ac pressure on the main display to read the afr instead of pressure also i cant get my lc1 to connect to the lap top any ideas??? 94 lt1 tuner cats data master
Old Jul 1, 2012 | 02:53 PM
bobdec's Avatar
Re: lc 1 logging
https://www.camaroz28.com/forums/com...riteup-535603/ Some put a switch on the AC / LC1 lines to the PCM so you can switch the AC back on when needed. May require a PCM reset to clear any AC DTCs that occur with AC sensor circuit to PCM opened when using LC1.
Old Jul 1, 2012 | 04:35 PM
Re: lc 1 logging
Let's move this to the "Computer Diagnostics and Tuning" forum.
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
Sep 18, 2015 03:46 PM
tommalcolm
Sep 11, 2015 03:39 PM
