diagnostics cable
Old Jul 5, 2012 | 08:22 AM
z28_4life's Avatar
diagnostics cable
I have the obd1 cable with akm cables 8 prong adapter. The problem is most new laptops no longer carry this type of connection (8 prong). Is there a cheap adapter I could run to go from the 8 prong to a usb type connection at radioshack or do I have to order a whole new cable specifically designed for usb?
Old Jul 7, 2012 | 02:54 PM
bobdec's Avatar
Re: diagnostics cable
You really have to do some searching.. Assume you are talking DB9, 9 pin serial RS232, OBD1 cable. You can purchase a Serial to USB adapter, but not all adapters will work. There used to be a list of supported adapters from some of the ALDL cable manufactures around, I think TunerCat sells an adapter for $55 ($$$) I have not seen an updated list lately. Incorrect adapters can cause problem, so that's why many have bit the bullet and gone to USB ALDL cables w/newer drivers. Maybe someone will chime in and tell what adapter they are using for the serial cables.. if it's still available.
Old Jul 7, 2012 | 08:59 PM
Andrew/AKM used to recommend/sell the Belkin F5U103. Got to be a 7-8 year old part at this point.
Andrew sold all his designs to TunerCats.... they have a USB to Serial kit with converter and cable for $59.25 including shipping:
http://www.tunercat.com/cables/aldl.html
G-BODYT56
Jan 14, 2022 11:14 PM
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
marlar98
Sep 19, 2015 07:53 AM
Aug 24, 2015 06:41 AM
