looking for .bin files to compare data
Old Aug 7, 2011 | 03:41 PM
chief455's Avatar
I am trying to correct my cars tune and want to understand the tables better. I am new to tuning a PCM
In my 30+ years building old cars the key has been research, reading and looking at known good running combinations.
Anyone offer to share their tune (similar to specs below) please pm me.
I'll just be asking for your specs and give you my email
Or, if you want to look at my tune to evaluate it - let me know.
The issue is it goes very rich at high rpms / under boost.
thanks
95 f-body
383 well built forged blower bottom end
9.3:1
ported LT1 heads
227/239 @ .050 .560/.577 lift, 114 lsa/110 intake c/l
Siemons Deca high imp 60lb injectors
58mm BBK
Walbro 255
SLP 1 3/4" mid lengths
y-pipe, 3" catback
DISC twin intercoolers
12 rib, 12lb pullies
neal Chance 3600 stall, TH400
9" 3.75 gear
315/35/17 nittos
Old Aug 8, 2011 | 12:15 AM
97WS6SCharged's Avatar
Re: looking for .bin files to compare data
Going to be hard to evaluate it without logs and/or wideband readings.
How rich is it going under boost? 11:1-11.5:1 should be fine for a FI motor.
Old Aug 8, 2011 | 05:38 PM
chief455's Avatar
I am finding that out. My cable won't read my PCM yet to log, working that out.
I don't have a wideband in the car yet but on a dyno the car was running ~ 14.2:1 up to around 3,000rpm then under a WOT pull A/F ratio dropped from 5100 rpm = 10:1 to 5800rpm = 8.8:1 with ~51psi fuel, 10.9lb boost
I would like to see how other similar builds have their tables set up - just as a learning tool. I read tons of 'how to tune' things, but actually comparing numbers helps me see the picture.
Old Aug 9, 2011 | 05:22 AM
You might want to ask on the "Computer...." or "Forced Induction" forums.
Old Aug 9, 2011 | 06:45 PM
ACE1252's Avatar
http://www.monodax.com/forums/
File request forum....
http://www.monodax.com/forums/tunercat-file-request/
Old Jun 11, 2012 | 09:30 PM
chief455's Avatar
joined site, thanks.
back running with new engine, same specs but AFR 195 heads and lowered (8.5:1) compression
I have the .bin and .uni files if someone cares to try and help tune it in
Novo
Jun 14, 2016 02:58 AM
NewsBot
Sep 30, 2015 04:20 PM
CARiD
Sep 30, 2015 05:44 AM
NewsBot
Sep 15, 2015 11:53 AM
NewsBot
Sep 14, 2015 02:02 AM
