LMA-2 Setup on LT1
Old Sep 13, 2011 | 08:22 PM
Meen95z's Avatar
Question LMA-2 Setup on LT1
I have a 95' Lt1 and have a digital 6 plus and lm-1 wideband. I want to hook up the lma-2 so I can use log works. It says on innovates instructions, the tach signal can not exceed 5volts. Well msd box puts out a 12v tach signal it says. How do I hook the lma-2 up on my car? anyone done it?
Old Sep 15, 2011 | 03:32 PM
Kevin Blown 95 TA's Avatar
Re: LMA-2 Setup on LT1
I looked at the manual for it and it's a little vague. It says that the AUX inputs can't go over 5V, but it doesn't say the RPM pulse can't. I think you should go on their web site and post in the forum or just call them to be sure. I bet it is protected for a higher voltage like the Aux Box is. I have the SSI-4 and it is hooked up to the tach output of my ignition amp. I doubt they would limit a tach input to 5V because who on earth would have that?
DirtyDaveW
Dec 1, 2016 05:37 PM
HectorM52
Jun 23, 2016 08:42 PM
4586
Dec 31, 2014 02:21 PM
squinn
Aug 4, 2002 01:06 PM
