OBDI PCM Issues?
Old Aug 2, 2011 | 07:15 AM
DAVE00's Avatar
OBDI PCM Issues?
Ok guys, I hooked up my new cable and still have "Data Err" issues in datamaster. I have made a recording as I am now getting DTC's flashing all over the place very quickly and I am starting to think that my PCM has issues. The car runs great, however this whole thing started about 3 weeks ago with the PCM showing false knock and now I see this. I can send you a copy of my .UNI file recorded in Datamaster (pm me your email) as it was recorded only at idle for about 5 mins and I am showing the following DTC's flash on and off very quickly:
24, 65, 34, 82, 22, 44, 27, 41, 80, 48, 44 and 83
Half of these are Transmission related and I have an M6?
I think my PCM is going bad or has issues, any one else have any advise?
(PS: I know my BLM's are split as that is largely do to the fact I havn't driven it to help level out the LTcounts and also my cam size on a 108lsa).
Old Aug 2, 2011 | 04:47 PM
siguy's Avatar
Re: OBDI PCM Issues?
i am having the same type of issues my codes are 48 ,51 18,41 does you car run at all (mine car will run for about 20 min go into limp mode and will and if i shut it down can not restart for about an hour after is cools down) i have also replced 2 opti sparks thinking they were bad. so i am pulling my hair out not sure if the pcm is bad of good or something else is going on
Old Aug 3, 2011 | 07:34 AM
DAVE00's Avatar
Mine is not quite that bad as my DTCs flash randomly and do not stay. The car runs perfectly and does not shut off or not restart. I'm thinking mine is a grounding issue as my ground strap (driverside head to body) is pretty corrroded and I will be replacing it today to see if this helps. I swapped out PCM's yesterday with a spare I have on hand and didn't help. We'll see if this ground will help and I'll let you know.
Old Aug 3, 2011 | 09:33 AM
bobdec's Avatar
PCM gets ground from ground stud on block passenger side down near the starter. Also two wires on ground stud on front of head drivers side go to PCM injector drivers. The stud on head should also have 1 black wire to ICM and coil and a braided wire to chassis. Obviously both ground studs require the chassis is properly grounded to battery negative check the main ground wire from battery and also the ground stud on the passenger fenderwelll. Won't hurt to verify the +12 v distribution stud is Ok on the fender well.
Old Aug 3, 2011 | 10:03 AM
DAVE00's Avatar
Correct, and all grounds have been checked, sanded, cleaned, etc... The only one that is questionable is the braided grounding strap as it's pretty green/corroded from age and I've heard this can cause interference with the signals from the ALDL from PCM.
Old Aug 3, 2011 | 04:27 PM
siguy's Avatar
Yes i have gone through Wiring harness as beast i could so i am not sure what the freak is going on with my car. I am boggled the only thing I waiting for a PCM to come in and hope this will be the problem...
Old Aug 4, 2011 | 06:32 AM
DAVE00's Avatar
K, the ground strap didn't work, still have "Data Err" messages and random DTC's. Really tired of chasing this gremlin, so since she's running smooth and strong, I'm going to leave it be for now. Let me know if you ever figure yours out.
Old Aug 4, 2011 | 04:35 PM
siguy's Avatar
will give you an update once the pcm comes in
HectorM52
Jul 30, 2017 11:46 AM
aj2494
Mar 12, 2015 10:17 PM
94Form
Feb 10, 2015 11:23 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
