Getting Code 61
Old Sep 2, 2011 | 11:14 AM
bw_hunter's Avatar
Getting Code 61
Hi Folks,
I just did a AC system rebuild and replaced all seals, the compressor, the receiver/drier. The system worked great for a week and then simply stopped.
The system is holding refrigerant pressure just fine..
No SES but a scan of the computer yields a code 61. Can anyone define that a little better for me?
Thanks in advance...
Old Sep 3, 2011 | 10:15 AM
Re: Getting Code 61
From the 94 shop manual:
The PCM monitors A/C refrigerant pressure and A/C evaporator temperature to determine if the A/C sysstme has adequate regrigerant (R134a) charge. The PCM will disable the A/C clutch whenever A/C refrigerant charge drops below a predetermined value, to reduce the chance of compressor damage. The PCM will cycle the compressor more frequently if the charge is only slightly low.
The PCM determines A/C charge based on the A/C refrigerant pressure and the A/C evaporator tmeperature. The PCM uses these two inputs to calculate A/C refrigerant charge.
DTC 61 will set when: The PCM claculates regrigerant charge to be below a predetermined level.
Action taken: If the PCM determines A/C refrigerant charge to be low, the A/C clutch will be disabled and DTC 61 will be set. DTC 61 will be stored in the PCM memory, but will NOT turn "ON" the MIL.
Old Sep 3, 2011 | 12:14 PM
bw_hunter's Avatar
Re: Getting Code 61
Thanks Injuneer.
I put the gauges on it and found slightly low pressures. I added more refrigerant to get the correct pressures as outlined in the service manual. When I did the original work it was very hot(ambient) and I may not have put in enough.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
