DTC 34 map sensor low
Old May 1, 2012 | 02:26 PM
bazzi's Avatar
So this is the second time i had this code come up, i changed the MAP sensor like a year ago maybe 2 and it was fine, but yesterday it came back. Whenever i was stopped and started to take off the car would almost die, it was like no fuel was getting into the engine. Maybe its bad wiring? help!
thanks
Old May 1, 2012 | 05:04 PM
Re: DTC 34 map sensor low
That code sets when the PCM detects a very low voltage, indicating a vacuum higher than the engine can produce. Could be a short in the system. Have you checked the MAP harness connector? They seem to dry out and crumble over time, producing erratic MAP readings. The PCM is basing the spark advance and the long term fuel corrections on the MAP reading, so if the signal is bad, it's going to affect the way the engine runs.
I have no way of telling what year your car is but in a 94 for example, the code sets when MAP drops below 16kPa. At idle, that's about 1/2 of the value you would expect to see. When the code sets, the PCM defaults to calculating MAP from throttle position and engine RPM.
If your car is a 93, the impact is even more severe, because MAP is a key component of the speed-density calculation for fueling the engine.
Why not add the year of your car to your signature?
HectorM52
Jul 30, 2017 11:46 AM
mightymouse383
Jul 20, 2016 07:34 AM
timmy39120
May 8, 2015 11:41 AM
99TransAmWS6
Mar 22, 2015 11:00 PM
Fatdog2
Feb 13, 2015 08:19 PM
