SES Light at idle (high map sensor reading)
Old Jul 29, 2011 | 10:31 PM
Meen95z's Avatar
Question SES Light at idle (high map sensor reading)
For about a year now I have had this problem at idle only with it throwing the ses light on my 95' Trans Am. Idles fine, just really rich, once you give it gas it goes off. I checked on my scanmaster and the map reading was around 24-25 then went down when it would rev over 2,000. Its a built 383 with a decent size cam, ported and welded intake with a twin 58mm. Anyone tell me how to fix it? Or what the deal is?
Old Jul 30, 2011 | 12:27 AM
Re: SES Light at idle (high map sensor reading)
At idle, the PCM looks at the MAP sensor, and if the MAP is over 68kPA (exact number seems to vary from year to year?), it sets a code. If your cam is big enough, its possible your MAP is above 68kPa at idle.
You are indicating that ScanMaster reading at idle is "24-25" I'll assume that in inches of mercury ("Hg). That would correspond to about 80-85kPa, which would indicate a fairly radical cam. In effect, its telling you its only pulling about 6"Hg vacuum at idle. Check the vlave adjustment.
Old Jul 30, 2011 | 07:21 PM
Meen95z's Avatar
I checked the valve adjustment seems good. I do recall it didn't do this until I put my nitrous plate on. I have a 58 mm tb, nitous outlet monoblade plate, welded and ported lt4 intake. Has a monoblade opening. What's your opinion there?
Old Jul 31, 2011 | 09:40 AM
Shouldn't affect anything as long as there are good gaskets on both sides of the plate.
What is "welded" on the intake?
Old Jul 31, 2011 | 12:06 PM
Meen95z's Avatar
Ill double check the gaskets. The runners are welded up on it. Llyod Elliott did the intake.
Old Aug 1, 2011 | 07:00 PM
Meen95z's Avatar
Made some new throttle body gaskets with some felpro gasket material and used some copper spray on the surfaces to make sure it sealed good. Still has a see light at idle 1100rpm and goes off at 1500ish. Anymore ideas?
Old Aug 2, 2011 | 05:36 PM
Must be the cam. Has it been tuned on a dyno, or is it a mail order tune? That can affect the vacuum at idle.
HectorM52
Jul 30, 2017 11:46 AM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
