twin turbo impalla ss troubleshooting help
Old Sep 12, 2011 | 09:29 PM
lt1ownsall's Avatar
whats up guys.
I have a twin turbo impalla ss with a forged 383 yadda yadda yadda.. very expensive build.
Tuned 2bar speed density and we have an issue with a 2000 rpm shudder / studder / surge. The ve is NAILED and the surge pretty much cuts fuel and leans out .
Things I have considered. Please let me know if you consider anything else..
Plug wires - one is loose or jacked ( new set btw)
plugs - cracked or fouled from early bad fueling in the tune ? ( new plugs same time)
vac leak?
egr - gone
emmissions - gone
optispark vent - he has it hanging loose.. says you cant put boost on it.. ????
air pump - gone!
optispark - brand new dynospark unit iirc?
Vacuum leak?
IAC?
one sticky injector ? 60# brand new motos
there is no maf
what else??
Old Sep 14, 2011 | 08:19 AM
lt1ownsall's Avatar
Re: twin turbo impalla ss troubleshooting help
Im thinking it may be cam surge as well. Im going to put the car back into open loop and mess with the low rpm timing tables.
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
