Check Gauges Light flashing rapidly
Old Oct 28, 2011 | 08:50 AM
7designs's Avatar
I rebuilt my LT1 with heads, cam and supporting parts. I bought a PCM from a 94 to run in my 97 SS swapped it in and added a tune.
But I notice the "Check Gauges" light flash very rapidly at times. All gauges are reading like they should. What could be causing this?
Old Oct 29, 2011 | 02:23 PM
bobdec's Avatar
Re: Check Gauges Light flashing rapidly
On a '94 check gauges illuminates for alternator voltage high or low, oil pressure low, or coolant hot. The circuitry is all internal to the dash cluster, nothing to do with the PCM. However I do not have schematics for a '97 so I can't help.. Maybe someone else could chime in..
Old Oct 29, 2011 | 04:05 PM
moparman's Avatar
Normally, the flashing SES means a misfire.
Old Oct 29, 2011 | 05:00 PM
7designs's Avatar
Yes, but this is check gauges light, not service engine soon light.
Old Oct 29, 2011 | 06:30 PM
moparman's Avatar
Geeze, for some reason I missed the "Check Gauges" part.
Old Oct 30, 2011 | 08:06 AM
bobdec's Avatar
Just a thought... Since the gauge dials are buffered to move smoothly maybe you have a loose or dirty connection on the oil sensor or temp sensor (on left head) that is bouncing the signal but not long enough to move the gauge. If it was an alternator connection/problem you would probably see lights dim/brighten.
Old Oct 30, 2011 | 08:07 AM
I did, too, the first time I read it. I have never heard of the check gauges light flashing.
Old Oct 30, 2011 | 09:08 AM
7designs's Avatar
Yes, it is a weird one. It is annoying, might just pull the bulb because I watch my gauges religiously and do not need a light to tell me to look at them, but I would rather fix it right.
David Dorris
Jan 17, 2015 08:10 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
