Easy or Hard to install Shift kit??
Old Mar 7, 2003 | 01:19 PM
nothingeined's Avatar
so i was walking through my parts store today and they were blowing out the B&M Shift Kit for 9.99 so i bought one because i always read about people having. is it a worthwhile mod?? and is it easy to install or do i have to have someone install it for me?? i never really work in my engine. i do normal everyday driving around town and sometimes catch a race between stop lights. what are the benefits or cons of having this kit?? any help is greatly appreciated!
Old Mar 7, 2003 | 02:45 PM
V6Power's Avatar
Is it the electronic one or the mechanical one?
Old Mar 7, 2003 | 03:30 PM
1fastV6's Avatar
if it was 10 bucks it has to be the electronic one, so its not worth it- compared to the mechanical one.
but if it is the mechanical one and they dropped $100 in price for some reason, then what a steal
i havent put in an electronic one, but its really not that hard, but then i personally dont think its worth it. there is a reason it is 10 bucks.
Old Mar 7, 2003 | 04:10 PM
scamaro's Avatar
i have the mechanical one one my car, stage 2. i like it alot, though my passengers hate it (1-2 shift is hard). i have heard bad things about the electronic one though. such as it increases your line pressure and ends up destroying things. i installed mine and it was about a half a day job (went real slow due to the case of beer ) other than that i have had it on there for about 3 years with no problems other than age( 118,000 miles on my tranny, no rebuild yet) well good luck on either route you take.
Old Mar 7, 2003 | 05:20 PM
i think ill just return it then cause it is the electronical one. thanks a lot for the help!!
Old Mar 8, 2003 | 10:13 AM
Satellite98's Avatar
Does it chirp the tires in second? My blazer does that with the shift kit, whether you want it to or not.
Is there a way to turn the mechanical one off? It can be cool sometimes...but sucks in the rain-the back end kicks out some if your crawling around a turn and it hits second...there are other times when it can become annoying too. NOt sure if I would put one on my camaro.
Old Mar 8, 2003 | 01:01 PM
scamaro's Avatar
there is no way to turn the mechanical shift kit off. unless you get back into the tranny and change it back to stock.
Old Mar 8, 2003 | 02:47 PM
Didn't think so, same with my truck
Old Mar 8, 2003 | 04:45 PM
Bliggida's Avatar
Not only is performance increased, but with a shift kit another by-product is that it actually helps your transmission to work more efficiently. The softer a shift is the longer the clutches must be engaged - that builds heat. Some have estimated 25 degrees rise in temperature per shift in racing conditions. A shift kit shifts faster, the clutches are engaged less, the longer they last.
Combined with a deep pan, a cooler, and relocation filter, Your transmission would quite possibly hit 200,000 + miles with no work needed.
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
RedLineRev
Jan 23, 2003 03:51 PM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
